I'm going to use both 12ga. pins for power, and drill/tap the plastic for a bolt/stud for my ground. There is a thick area (circular) on the plastic flange that is about .5" thick that I tapped for a m6x1.0 bolt. I will probably run a 10ga. ground.
Originally Posted by Chitoki
(Post 24088567)
I had a close issue. What we had discovered is that you must run the same gauge wire all the way directly to the pump. If you run a larger gauge and then connect it to a smaller gauge, then you will get resistance at that connecting point causing this.
Bringing this thread from the dead.
I have a problem, working with Jeff Evans to tune my 06 with SOS supercharger, id1050x and upgraded AEM 340 fuel pump with SOS rewiring kit. There is some sort of fuel pressure issue as on my previous tune to get 11.0 afr the injector duty had to be raised to 96% at redline to provide enough fuel, this is with 3.8" pulley and 9.5 psi (only). Does anyone have any idea what is the issue of the pump not being able to supply enough pressure? I used new fuel filter at the end of the tank and followed this thread in details. Jeff suspects o-ring being a culprit at the pump outlet - any thoughts? Thank you. |
Check out this lengthy thread. Several potential things identified, buried in this post or that.
https://www.s2ki.com/forums/s2000-fo...boost-1208364/ |
Originally Posted by wojtekj1977
(Post 24873145)
I have a problem, working with Jeff Evans to tune my 06 with SOS supercharger, id1050x and upgraded AEM 340 fuel pump with SOS rewiring kit. There is some sort of fuel pressure issue as on my previous tune to get 11.0 afr the injector duty had to be raised to 96% at redline to provide enough fuel, this is with 3.8" pulley and 9.5 psi (only). Does anyonje have any idea what is the issue of the pump not being able to supply enough pressure? I used new fuel filter at the end of the tank and followed this thread in details. Jeff suspects o-ring being a culprit at the pump outlet - any thoughts? Thank you. |
It's only one data point so take this for what it's worth to you. I've had that fuel pump do that exact thing on the dyno, and it only had the miles it took to drive to the dyno. My tuner immediately said the fuel pump itself was the culprit. We swamped pumps and all was good.
Originally Posted by starchland
(Post 24873178)
any way you can check actual fuel pressure at the rail?
Thank you. |
Yes, such a restriction is mentioned in that thread I posted. Someone had such an issue, explains where it was, how they fixed it.
(Post 24873184)
No option to attach a gauge, the pump is literally new with 200 miles on it. The only factor telling us that the pump might be a culprit is that to get desired AFR at redline we need to max 1050x, which comparably in other setups were in 70% Duty (vs 96% that we need to run). At this point my biggest question is it a pump or is there an o-ring or something else that would form an obstruction and bleed the fuel into the tank instead of sending towards the injectors? Let me know your thoughts.
Thank you. |
