Originally Posted by Chitoki
(Post 24088567)
I had a close issue. What we had discovered is that you must run the same gauge wire all the way directly to the pump. If you run a larger gauge and then connect it to a smaller gauge, then you will get resistance at that connecting point causing this.
It has been a while since I did fuel pump wiring. Is their a spare pin location where you can split the power to two pins, then merge them back together inside the tank?
Yes there is one spare next to the smaller fuel level pins.
I was thinking about using this but not sure it's a good idea to just upgrade one. |
If you use the second pin, you could split the wire into two, then merge them back together inside the tank. That would eliminate the restriction of a single pin.
Originally Posted by RAIN H8R
(Post 24089978)
The dirty solution would be to use the spare pin as an extra positive and then wire the fuel level negative together with the pump.
Originally Posted by riceball777
(Post 24090477)
Riceball, what did you end up doing with this issue?
(Post 24118714)
Good to hear you were able to resolve the issue, for under $100.
did you solder the crimped pins? this may aid in preventing a nuclear meltdown in the future. I just ordered this kit for my car yesterday. I'll see what I can come up with as a preventative measure. |
