my entire build....(so far)
#41
Originally Posted by jwa4378,Feb 11 2009, 10:19 AM
GDM S2K -
Our cars are NOT vented through the gas cap. Older model vehicles were (old v8's from the 60-70's). When the EPA found out that gas fumes were being vented, and it was not good for the environment, and did not allow it anymore.
Our car has what is called an "Evaporative Emissions Control" system. It basically vents the gas tank into the intake manifold, where the fumes are burnt and passed through the catalytic converter (supposedly... ).
I dealt with this vacuum system when I was having issues with my BOV surging (vacuum was not strong enough from the rear-most port on the manifold, so I relocated the BOV vacuum line to the nipple just rear of the throttle body... that is 1 of 2 vacuum sources for the EEC system (the two sources T together under the manifold and go to the purge joint, I think).
John
John
#42
Originally Posted by btstone84,Feb 11 2009, 01:49 PM
on the cap that holds the factory fuel pump in it has holes that used to have lines. i used those for my vent, along with the hose that runs next to the cap that VENTS also
the lines were the feed nd return. how are you venting it threw the gas cap? got pics?
#43
there is a little hose that runs right next to the hose where u fill the gas up, it is a small vent
then the line that retuned fuel on the original factory set up. i have small hoses on them that go to "no where" and they vent also....i shit canned the evaporating sytem...if i had no vent i wouldnt be able to get gas out of the tank to the engine
#45
Originally Posted by jwa4378,Feb 11 2009, 01:19 PM
GDM S2K -
John
John
#46
i want saying 2 diff things. i just said you dont need a vent. its already there
people just dont understand simple, so you have to make it complicated
#47
Originally Posted by btstone84,Feb 10 2009, 08:34 AM
its the factory gas cap, i read in thats huge 1000+ page book about the s2k that it is vented
#49
Originally Posted by Tyraid2K,Feb 11 2009, 03:48 PM
when you stroke your car to 2.5 and buy a carbonetic 3 plate clutch it means you are serious,
I'm going to invest in rubber now...
