My build taken to the next level *701WHP/450TQ*
Old 12-10-2008, 06:06 AM
  #71
passmans2kny's Avatar
hmmm, might be interested bc my 750s are close to maxed out
Old 12-10-2008, 06:07 AM
  #72
kutsujula's Avatar
Yep with these no need for resitstor box or injector driver.
Old 12-10-2008, 06:54 AM
  #73
i dont have either with my 750s now, so if i decide to shoot for more power after the winter i might pick these up
Old 12-10-2008, 07:38 AM
  #74
Soul Coughing's Avatar
Originally Posted by kutsujula,Dec 10 2008, 08:58 AM
If anyone is looking for 1000cc injectors for there setup. Look at these first!
are these the new bosch 1000cc's that need no resistor box?
Old 12-10-2008, 07:51 AM
  #75
thats what he said 2 posts up
Old 12-10-2008, 07:59 AM
  #76
kutsujula's Avatar
yes
Old 12-10-2008, 08:09 AM
  #77
btstone84's Avatar
Originally Posted by kutsujula,Dec 10 2008, 05:58 AM
are you still using the factory fuel rail, if so then you are def limiting yourself
Old 12-10-2008, 08:32 AM
  #78
kutsujula's Avatar
The post is about the injectors not the fuel rail.
Old 12-10-2008, 09:16 AM
  #79
Mr. Nismo's Avatar
Things looking good man. Plug in play injectors FTW!!!!!! Seems you got fuel taken care of.
Old 12-10-2008, 09:38 AM
  #80
tony1's Avatar
The factory rail is more than sufficient for 1000cc injectors. When we're ready for more fuel, a secondary rail and 4 more injectors will be installed. 1000+hp fuel capability with OEM idle and driveability and fuel efficiency.
As stated, these injectors will fit an S2000 and all that's required is to install the injector clips. You can get the clips with pins to crimp on your factory wires (best way but requires the proper crimpers), clips with pigtails that you can solder or crimp on, or wireless adaptors that adapt these to a typical 'obd1' style connector (so if you have obd1 clips already these will be plug and play).
Quick Reply: My build taken to the next level *701WHP/450TQ*
