my build
my build
engine
-f20c
-aebs sleeved t sleeved block
-o-ringed
-88mm ross 9.5:1 ceramic coated top and moly coated sideskirts
-pauter rods
-arp head bolts
-arp rod bolts
-port matched head
-lightened,poliched, and balanced crank
-toda valve springs
-ti retainers
-rev extra duty x series valves(1mm larger on exhaust side)
-kaiten valve guides
-skunk 2 stage 2 turbo cams
turbo
-full blown sidewinder twin scroll manifold and dump tubes
-twin wastegates
-borg warner s300 83/75 1.00 ar
-3" intercooler piping
-aem boost solenoid
fuel
-full blown dual pump hanger
-dual 290 pumps
-full blown xxl fuel rail
-full blown fpr
-10an feed 8an return
-id1000cc injectors
engine managment
-aem ems v2
cooling
-mishimoto radiator
intake
-afi intake manifold
-bbk throttle body
im just about done with my build and cannot get the car to fire, it cranks but wont fire. ive checked sensors and checked the timing multiple times cause i know it wont fire if its off at all. i have fuel pressure but its not getting into the engine so i checked spark and im not getting that either? another problem is my fuel pump, if i plug the oem ecu in the pumps come on and when i plug in the aem nothing? any help would but thankful. i live in alaska so theres not to many shops to take it to, i want to get it fired before i take it to the dyno and to get tuned
-f20c
-o-ringed
-pauter rods
-arp head bolts
-arp rod bolts
-port matched head
-toda valve springs
-ti retainers
turbo
-twin wastegates
-aem boost solenoid
fuel
-dual 290 pumps
-full blown fpr
-id1000cc injectors
engine managment
-aem ems v2
cooling
-mishimoto radiator
intake
-bbk throttle body
call aem, the aem ecu sometimes does that. its a glitch in the aem. you will have to send it to aem and have it fixed. google it, thats where i read about it about a year ago. that is 100% it.
Things to check:
When you plug the AEM in, did you have a laptop connected to it and load the calibration map?
Base cal. map loaded? What calibration file are you running?
When ignition is on position, the fuel pump should prime.
