Motor swap questions - clutch
Im gonna be doing a motor swap in next week or 2, also removing my turbo kit. Want to do some preparation for supercharging the car down the road. Tapping girdle etc.
My Competition 1620 has served me well during my turbo days, PIA to drive but it works. But I know its way overkill for an S/C.
What are you SOS, Comptech, Vortech guys running?
**IF** I get an S/C kit, I will not run more than 10/12psi. That would put me around 240tq maximum I think.
thanks
thanks
Most people run either a SOS kit or an ACT pressure plate with stock disc.
The ACT is good up to 380 ft lbs i believe and has a close to stock pedal feel.
General opinion is to avoid puck type clutches for street drivable. That said, I'll be getting an ACT.
Has ACT changed their PP design yet? I loved the ACT SS kit on my MR2, wouldn't mind getting another one as long as the issues are worked out
[QUOTE=DBXFX,Aug 27 2010, 11:18 AM] Most people run either a SOS kit or an ACT pressure plate with stock disc.
found a nice 05 F22 w/ 20k miles for a good price from a reputable seller on here...
only thing that I have a concern about id the compression #'s I was told.
On my original F20 motor & the 06 F22 which I just wrecked, the best compression #'s were 250psi during a warm test.
He told me this F22 has 230psi in each, but test was done on a cold engine that was not in a car. Would it be safe to assume that once the motor is in my car, a warm test would give 10psi higher making it +240psi in each?
thanks
thanks
