Mase Kit
Originally Posted by Deception' timestamp='1311613030' post='20813002
scavenger pump from turbo drain to the TCT hole like the Ptuning kit... the pump is ~$300 IIRC + cost of lines & fittings
someone will probably say run it to the stock oil drain in the pan, but dont listen to them
Why add complexity to a system when it's not needed.
Unless you are on a road course with alot of left hand turns, otherwise it's overkill.
