Mase Kit
Old 07-25-2011 | 08:47 AM
LonS2k's Avatar
Default Mase Kit
I was wondering if there is a alternative way to run the oil return instead of tapping the girdle? is there a way without having to tap anything?
Old 07-25-2011 | 08:57 AM
Deception's Avatar
scavenger pump from turbo drain to the TCT hole like the Ptuning kit... the pump is ~$300 IIRC + cost of lines & fittings
someone will probably say run it to the stock oil drain in the pan, but dont listen to them
Old 07-25-2011 | 09:16 AM
s2knoob89's Avatar
Have a -10 AN bung welded on to your timing chain cover on the bottom left corner. I have this done on my car with no problems. I need to post pics.... Maybe tomorrow.
Old 07-25-2011 | 11:44 AM
riceball777's Avatar
persionally i just have a -10 an bung welded at the top of my oil pan and i never had any problems
Old 07-25-2011 | 12:31 PM
camuman's Avatar
Fbm taps the front top of oil pan. Been fine for me so far. I think the girdle is overkill. Top of pan is fine. When the car is running there is not enough oil in the pan to cause the drain not to work.
Old 07-25-2011 | 01:05 PM
steven975's Avatar
I was thinking the dipstick hole was a better idea, myself.
Old 07-25-2011 | 03:17 PM
Suzuka_Joe's Avatar
I saw a genesis that they had done it that way. A v6 that had a twin turbo rear mount setup. Scavenger pump to oil return thu dipstick. Lol. Terrible....
Old 07-25-2011 | 06:13 PM
Deception's Avatar
lol
Actually I was reffering to just running the oil return to the drain hole without a scavenger pump AKA greddy kit style AKA bad idea
Old 07-25-2011 | 06:37 PM
steven975's Avatar
That's how my SOS kit has it. With the (probably) lower flow through the SC, is that something that I should change?
The oil temp coming back should be FAR less than it would be with a turbo, though.
Old 07-25-2011 | 08:11 PM
Deception's Avatar
I tapped my oil pan at the front drivers side for my SOS kit. Companies just say to use the stock drain to keep cost/install time down, extra work scares away customers.
Quick Reply: Mase Kit
