Mase Engineering S2000 Turbo Kit Introduction
#761
Originally Posted by spectacle,Jan 25 2010, 10:21 AM
I would HIGHLY recommend everyone tap the girdle instead of the pan. One less thing to worry about.
2nd... dude with the mase kit, take off the vtec solenoid oil pressure sending unit, not need with ems and wont burn up
#762
Originally Posted by razzele,Jan 28 2010, 12:21 AM
that turbo and downpipe are massive!!
Is that the standard mase kit ?
so yes larger than the standard kit ..
#763
Originally Posted by stooky2,Jan 27 2010, 08:28 PM
30 plus psi of oil pressure and gravity, should not make a difference if you tap the pan or the girdle, hell the comptech uses the oil drain bolt and has no problems...
#764
Originally Posted by s2000442,Jan 25 2010, 08:10 AM
Lets see a pic of your pan tap.
what i did, spray it down with some simple green, inside and out... let it set...
scrub it down with a wheel brush.. hose it off.. drill it (i used "tap magic" to help with the drilling process) then repeat the cleaning process..
hit it with a burr grinder accordingly (to make it look like pic #1)
tack it on the outside, the warm it up and weld it on the inside..
#766
Awesome work Nick! Thanks for doing this for me. I feel a lot better about this part of the kit now. Hopefully this will help others about where to place the tap. I really did not want to tap the girdle.
