major boost creep
major boost creep
right i have a s2000 with kings performance stage 3.5 turbo package aem edu 1000cc id injectors holds boost up till about 7000 rpm then increases fast to well over 17 psi when it hits the fuel cut and idears i have tryed with the wastegate ran straight from the turbo housing and still the same ????? also where is the best place to map/set up my car in the uk ????
46mm wg should be plenty. problem when running a big free flowing manifold and big turbo (T4) like the kings at low boost is you will boost creep. if you turned it up to 17+ psi you'd be fine and wouldn't creep. thats why you need to match your turbo to your goal.
What turbo do you have? 6266 or bigger?
if you had a T3 flange and a 6266 or smaller turbo you'd be ok running 13-14psi for now. A bb 5857 and my pfab elt manifold at 11psi holds boost great. no creep, i have a tial mvr 44mm. i'm turning it up to 14psi when i retune and i expect it to spool faster and hold steady boost just fine
