maintenance pre turbo
i have a 2001 s2k. i am either going with irtb's or a turbo. i will have around 70k miles before i do either. i was just wondering if i was to go with the turbo is there any maintenance or engine parts that should be replaced. ie. cams,clutch, or anything that could wear down fast due to the miles on the car and the added stress of the turbo
you're definitely going to need a new clutch, especially if it has 70k on it. other then that, I personally would change my fluids, not necessarily cause you need to, but just because.
They'll make your car impossible to drive. if it's sunny and 80 one day then 90 and full humidity thext, good luck getting your car to start... won't idle in cold weather.. ITBs are pretty much track queens for an S....I think, anyway. but they are sexy,
