Made 529whp at 15 psi - More boost to come
Hello Guys,
I tuned with Jeff Evans today and made 529 at 15 psi on 93 octane. First S2000 tuned by Jeff to make 529 at only 15 psi. We could not push the car anymore because the car started to over heat.
Jeff did a leak down test and cylinders 1,3 and 4 appears to be leaking. I am going to retorque the head on Sunday to see if that solves the problem.
Setup:
-Full Race manifold
-Dual walbro fuel pump (-10 Feed, -8 return)
-Inline pro three millimeter head gasket - 6000 miles on it.
-ARP head bolt
I hope it is not the head gasket blown . If so, which pistons and rods I should get that does not require the block to be sleeved?
Setup:
-Full Race manifold
-ARP head bolt
Originally Posted by yelis300,Apr 15 2010, 11:04 PM
Looks like some nice numbers there but it's the first time I see an S2k making that kind of #'s at 15psi.
Originally Posted by ny1honda,Apr 15 2010, 10:40 PM
I don't want to have to change the head gasket every 20k to 30k.
Pistons and rods will last longer than the 3mm headgasket.
Precision sc62
Precision sc62
What I'm getting at is....If you think the 3mm HG will have to be replaced every 20-30k miles, so will just the OEM HG with lower compression pistons and rods.
So, did you put a used HG on the car or was it on the car from a old set up?
One member ran his car on both a Dyno pack and Dyno Dynamic here in Md and it was a 15% differnce. I think they just read different I don't think the tuners try an manipulate them to read higher though.
