Looking to switch over from AEM v2 to Infinity 6 got some questions.
yes the AEM Uego will work so no need for a new wideband. For the traction control to work it needs to have the rear wheel speed sensors wired into the unit. boost sensor is your map sensor that i assume you have from your V2 setup since you are already boosted. The more sensors you install to monitor the more data you will have to find issues later on. It will help find weak points in your setup as most turbo cars develop . Oil pressure is needed to run the fail-safe incase of an oil pump failure or big oil leak. Same can be said for the oil/coolant temp sensors. Its a great upgrade from the V2 if you can afford it. Good luck
