Left cam position sensor A unplugged by mistake, inputs
Like the title stated I accidentally left the cam position sensor A unplugged (passenger side on valve cover) and started the car, it started up normal, once I noticed it was unplugged I turned off the engine and plugged it back in. Could this have caused any damage?
The ECU probably would have panicked in regards to timing and thrown a CEL, but if you didn't drive it then you're probably fine, so long as you're not hearing any bad noises. We've had a faulty crank position sensor on a K24 and it throws a CEL, but I guess it hasn't done any damage because the car survived the dyno
If you just idled the car then you're fine.
You'd just get a misfire if you had actually driven the car, as ignition timing would be off by the ECU. Would have been a problem if you had ran the car hard afterwards or left it unplugged for a long time, but definitely no harm if you just idled it.
