Kraftwerks high boost kit problem!
Old 08-26-2010, 05:52 PM
Marcosap2eg6's Avatar
Default Kraftwerks high boost kit problem!
I have 2007 ap2 and I recently bought the kraftsworks sc kit ( high boost) and runing into problems.. Whenever I floor it the rpms get stuck at 7k-7.5k at wot in all gears.. Please help what can it be??? Thanks no check engine light everything is stock just a stage 2 clutch kit
Old 08-27-2010, 05:25 AM
MasterForce's Avatar
my SOS stage 1 did the same thing after i installed a new big bore TB. my car made no power past 7600 rpms and sounded like fuel cut off but engine kept revving. but anyways after leaving it alone and driving normal it went away. something tells me i needed to break in the TB but i dunno. i rev up to 8600 now
Old 08-29-2010, 06:03 PM
GrandMasterKhan's Avatar
I sent you a PM. i'll be happy to help you out.
Old 08-29-2010, 06:31 PM
R1_Pilot's Avatar
Sounds like you are blowing off the spark. Gap them tighter.
J
Old 08-29-2010, 08:37 PM
well i have the denso iridium ik24 1 degree colder and i dint gap the plug. should i gap the plugs and whats the spec
Old 08-29-2010, 09:34 PM
.33 is what you should gap them to.
I was blowing out spark even with densos same as your above at the same rpm. The gap was at .43, but i was able to continue to redline it just felt weird.
Old 08-29-2010, 10:36 PM
Boofster's Avatar
You definitely want some BKR8EIX's at 0.33 (how they come anyway)
Aside from that you should seriously consider a tunable ECU. FlashPro is what $500 bucks these days?
Old 08-30-2010, 05:43 AM
Former Sponsor
TTS Performance's Avatar
Happens everytime I do one of my Rotrex st2(Supersport) conversions, just pull the gap down to 22 thou. and it'll rev right out.
Old 08-30-2010, 12:51 PM
Yea I em thinking of the flash pro but I'm stock so I'm goin to have to wait til next yeaR what abt meth injection would that help me out. So 22 thou I'll try it
Thanks
Old 08-30-2010, 02:02 PM
camuman's Avatar
kw hi boost kit doesnt need meth injection. blower is near max as it is. kw c30 blower is very efficient so you dont need the cooling properties.
just close the gap and enjoy.
Quick Reply: Kraftwerks high boost kit problem!
