Koyo Radiator with Comptech SC.
Okay. I have seen people with the koyo and an SC but I am not sure how they got it to fit. I have not pulled everything apart yet but without getting some fluidyne fans that are really thin I don't see how it will fit. I am running the godzilla bov so it pushes out a bit and the passenger fan is already almost hitting the intake tube? Do I have to buy fans or is there another way around it?
2nd: Do you have to replace the little soft weather strip between the front part of the chassis and the oem radiator? It appears to be stuck on with some sort of adhesive.
Thanks guys.
Thanks guys.
I'd guess they did replace the fans because it practically hits with the OEM radiator and the Koyo is about 3" deep.
2nd: No, you don't replace the weather stripping. It keeps it from hitting and keep the air going through the radiator and not above it.
