Kings Performance Yellow Bullet!
#42
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
what tire pressure are u guys running?...yesterday i took the car to the track made 2 passes which almost put me in the wall on low boost as soon as i got in my power band the ass kicked out and because very unstable. first pass was 12psi and the second pass was 15 psi which was way worst so im guessing i should have went 10 psi? im using m&h 26x10 slicks and 27x4.5x16 front runners
#43
And what rim width are you running again?
Sent from my VS870 4G using Tapatalk 2
#45
#46
Originally Posted by bobbyrandolph440' timestamp='1375556930' post='22704956
[quote name='Phill24' timestamp='1375552131' post='22704877']
[/quote]
No they make stiff side wall slicks to keep you from getting lose do to side wall flex
#47
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
You'll still have issues with stiff sidewalls if the track isn't there. More times than not, that is the problem. Don't start changing a bunch of stuff if the track is marginal. I did that a lot over the last 2 seasons thinking there was something wrong with the car and the setup and wasted a lot of money for no reason.
If the track isn't there, it doesn't matter what tire, pressure, suspension etc. you are running. With a 94.5" wheelbase, you don't have that working for you either.![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
I've tried several different tire setups and they all act the same on good and bad tracks. S2000's aren't easy cars to get down the track, it's just the nature of the way the car is. Eventually you'll just get used to it and start driving through it....haha.
#48
