InlinePro 5965 Turbo Kit
Well I spoke with Chris at Inline today and I am thinking about picking up their kit using the 5965 turbo. For anyone with this kit, is there anything else you would recomend with the kit other than the ball bearing upgrade and are you happy with it? Does anyone have any pictures or dyno's?
Thanks
Thanks
the ball bearing upgrade is not half as 'necessary' as the oil relocation, in my opinion.
the kit is incredibly well made. the install is very simple as well. i am currently stopped on the car but only because i'm sick . if i was healthy enough to touch a car i would probably have the whole thing done in 2 days start to finish.
the head gasket is not necessary but i think it should be done. you're missing out on about 100whp on average without it. stock wastegate pressure is set @ 7psi, and i believe that yields somewhere around 330whp. you can turn the boost up to around 9-10psi on stock compression and not have to worry about knock, but if you slap on a headgasket you can take that shit all the way up to like 20 lbs depending on injectors and management/tune.
what management and fuel system would you run?
A. I did not know they offered the smaller 5965
B. AEM EMS is not my cup o tea and Hondata is a PITA to deal with on an AP1
C. I had never heard of them as I came from the domestic market and I worried about quality.
So my ignorance at the time basiclly cost me what I really wanted in a S2K.
Hondata with BC & WB
InlinePro 5965
ACT PP
Meth
Low Comp Pistons
Ported Head
Oh and I have a new relocation kit in the garage from Inline minus the Oil Filter adapter.
the kpro install really isnt that terrible. getting to the crank sensor wheel is a bit of a pain but if you're going to do the hg at the same time it really isn't terrible.
i had bill do all my stuff and the extra work was not that bad, he said. maybe he can chime in.
im running pretty much the same turbo just slightly bigger and make 525 on pump. I love my turbo, spools nicely and pulls SUPER SUPER hard up top.
Id deffinately get:
aem ems with some wideband
3mm headgasket
750cc+ injectors
oil filter relocator kit
arp exhaust manifold studs
stage 8 bolts for turbo and wastegate
some kind of clutch, i used competition stage 4
here is my dyno graph:
heres a pic of the upgraded turbo i got from inlinePRO sc6165s vs sc6152e
heres a pic of the kit installed on my car
You are deffinately going to love it. Dont do it without doing the headgasket. That is the only reason i bought this car because of that headgasket you can make 500+ whp safely on a stock motor on pump gas.
Do it right once and be done with it.
Id deffinately get:
3mm headgasket
750cc+ injectors
I was looking at this kit b/c I want full boost by 4k so that day to day driveability is still excellent. So I will sacrifice a top end for a good lowend spool. With the HG, I was hoping for 400-450WHP, I will most likley need to wait until either the first of the year or spring to unload my car then the search is on. I am thinking red 2005. If I want more past the 400-450WHP meth, nitrous or propane will help me get there.
i sent you a pm regarding this, but i think you will be happy with this kit. Also I would not shy away from the aem ems as well. My car drives and runs just like a car with an oem ecu. It only takes an extra one or two cranks to get it started but hardly a big deal. I even had to move the car when it was around 30F and it took a bit to turn on but it did crank after a few seconds. As long as you have a good tuner you should be good. This is how my kit looks like with the 5965
Scott,
Like I mentioned from our conversation, I think you will be very pleased with this turbo and our kit. If you have any questions please dont hesitate to give me a call.
-Chris
