Inline Pro Engine #3 - It's actually over this time.
#21
I wouldnt call what you're experiencing a build error, but it really needs to be torn down to see the pistons.
cylinder 3 sees more air because of the way the manifold is designed. If you put individual widebands on the cylinders youd see #3 runs leaner. This is why when people have issues 90% of the time its on #3.
Why yours only shows foreign debris on that one cylinder I cannot answer.
Is that a bored FRM block? Ive been building these for awhile. Just a suggestion, stay away from boring/honing FRM liners. I've never seen them last. Sleeve it or find a block with good bores.
But doesn't honda say they can be bored?
#22
FRM bore is tricky. I am not even sure if the few that are capable of refinishing FRM bore are still around!
Sleeves, find a good stock block, or alternative coating (needs a bit more time to tell) are probably the only block options at the moment.
With so many variables, getting to the root causes of the failure might not be easy. But super important though.
If Jeff tuned the car, the tune likely isn’t the issue.
#23
It wouldn't necessarily leave any marks on valve as it passed through.
#25
I'm in touch with Jeremy Allen who also recommended sleeving for what I'm looking to do. I'm going to be dropping the motor off to him for a sleeve/rebuild in a few weeks.
#27
This is news to me. I'm not a professional engine builder, but I'm currently building a spare block, and during my research of what pistons to use I found only Mahle *advertised* FRM friendly pistons.
#28
I'm curious now if the use of the CP pistons has been the issue with this build all along, just like in the past.
#29
Mahle pistons is what I have always heard were the only pistons to use in the OEM FRM bores. This has been known since I can remember, maybe since 2003 even. Has that changed? It was always evident that any other piston besides the Mahle being used in the OEM FRM bores had issues. I think this was due to Mahle being the only piston that strictly abided by what could be used with FRM bores. What that entails, I'm not positive on though.
If those plugs are in order cylinder #2 looks a bit lean. Have your injectors flow tested.
Spoolin (08-07-2023)
floridawater
07-27-2022 08:39 AM
passmans2kny
11-08-2010 06:34 PM
