Are the inline head gasket worth it ?
Im about to purchase the inline head gasket and i was wondering if anyone on the board has one, they say you could run higher boost *safely*
ill be running speedcraft/ emanage/ rc 550
is it worth it ?
thanks guys -kit-
is it worth it ?
thanks guys -kit-
is it worth it ?
is it worth it ?
i would say its worth it. the compression is the only thing holding this engine back from being turbo friendly. after that the rods will be the next weak link as far as the engine goes.
how much are the gaskets running?
Originally Posted by ideugene' date='Feb 19 2005, 08:43 PM
is a separate modified timing gear necessary? can adjustments be made to the stock one?
i like to know also. Why is this necessary anyway with a thicker headgasket?
Originally Posted by hboy7777' date='Feb 20 2005, 03:47 AM
there is no adjustment that can be made to the stock one, and yes it is necessary because the more you lift the head away from the block(3mm headgasket) the more the cam chain tightens and ends up throwing the timing off. thats the main reason for offering it with the gasket.
Originally Posted by Venomous S' date='Feb 21 2005, 08:31 AM
I just spoke to Inline pro and they said you can adjust the stock gear, you have to punch out a pin and you can move the gear. Unfortunately i have no details...
