Injectors?
Looking for best injectors (size) fo the following situation:
300 - 350 hp (<400whp)
10 lbs of boost or lower, probly 8 psi
InlinePro turbo kit with GT 35/61
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
With the information you have provided I personally would recommend 750cc injectors.
Currently I am running a comptech supercharger with 3.25" pulley. On a very hot humid day she was able to make 358whp pushing 9.75psi at the motor, but my tuner said on cooler temperatures I should make another 1 - 1.5psi. He said once those numbers are hit I would be at 57psi in the AEM Fuel Pressure Regulator with Injector Duty Cycle being at approximately 84%. These numbers are using RC Engineering 650cc Injectors.
However, someone on this site may be able to correct me. My knowledge is only from Supercharged Setups. A Turbo may require a much larger injector size for obvious reasons.
Hopefully someone - such as AusS2000 will be able to comment!
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
Originally Posted by RZFD,Aug 26 2005, 10:50 AM
I'd go ahead and get 880's. You'll want more later, and if your tuner is any good you'll never know the difference.
750cc sound about right?
warpspeed2k2
02-27-2003 04:15 PM
