Injector info
Injector info
I'm not looking for big horsepower --- 350 the most.
Can someone tell me if this injector will work & will plug and play (no monkeying around putting resistor or something).
I appreciate any help.
http://tinyurl.com/6jo7k4e
Oh for rotrex C30-94 just 8-10psi boost. Will stock injectors works?
A friend gave me a Siemens Deka 650cc with a part number 07961, anyone out here can tell me if this is the right
Siemens injector that will plug and play to s2000? Thank you
I have just looked on your profile and seen that your car is a 00 model, so unfortunately those injectors won't fit. They would fit in a DBW car though. I "believe" that the injectors you are looking has an 8mm o-ring on the fuel rail side..( i saw someone comment on the homepage a while ago about the size, someone please correct me if my memory is incorrect)
If you want some decent injectors that will be fine for 8-10 psi get some ID725's: http://www.injectordynamics.com/ID725.html
If you plan on upping the boost in the future go for some ID1000's
Scroll down to the bottom, the ones you would require are the ID725-60-11 or the ID725-48-11 (I believe the 60's would require fuel rail spacers though). I have a DBW car so let someone with a pre-dbw car confirm that the o-ring sizes are correct for you.
Banned
you'll need upgraded injectors... i'd suggest 750cc ID or the 675cc seimens injectors
Dan Thank you very much.
I used to have a turbo Hayabusa and I used the Honda s2000 injector from 2001. The hayabusa injector and the honda s2000 injector has the same
diameter head size at the fuel rail.
I compared the Hayabusa injector (made by keihen) vs the Siemens Deka injector and the head (fuel rail side) looks identical.
I will check it again and use a micrometer to measure it...just to make sure it will fit and will not leak.
Worse thing can happen is buy a fuel rail.
The ports are the same size, just the dbw injectors are a little shorter than pre-dbw injectors.
Nice to hear the port are the same.
I think 650cc is good enough for my projected 8 to 10 psi boost. I'm not going to boost beyond that.
Besides, a friend gave it to me for free.
