Immobalizer problem 2 days after tune
Old 05-09-2011 | 12:12 PM
rsmatti's Avatar
Default Immobalizer problem 2 days after tune
I got tuned 2 days ago.
But the problems started today.
im outside of the car, i unlock the car, open the door and the immobilizer turns on and the cars alarm goes off (not the panic alarm) this is a completely oem alarm and iv had the car for 5 years now
its a 04 ap2. im clueless it wont let me start the car
no matter what i do the alarm keeps going off whether i lock or unlock the car inside or out once i get it the alarm turns on and wont let me start the car.
Old 05-09-2011 | 12:43 PM
Deception's Avatar
what kind of engine management? piggy back im guessing since your immobilizer still works (no pun intended)
Old 05-09-2011 | 02:16 PM
GrandMasterKhan's Avatar
are you unlocking the car with the key or the keyless keyfob?
If your OEM is armed it will cause this exact issue. You'll need to hit unlock on your remote twice to disarm the system.
Old 05-10-2011 | 05:18 AM
rsmatti's Avatar
Im running ems version 1
that what I dont get ems doesnt control it anymore.
when i unlock the car outside even if I hit the unlock button 4 times the red light is still flashing inside the car and when I open the door alarm turns on.
it's the oem alarm im stumped on this I pulled out a blue fuse and problem is solved but still doing get why its doing that?
Old 05-10-2011 | 09:41 AM
DFWs2k's Avatar
is the oem alarm tied to the immobilizer? if so, since you don't have the immobilizer anymore, that could be messing with the alarm
Old 05-11-2011 | 09:38 AM
egprelude's Avatar
The alarm should be completely separate form the immbolizer.
Try this: Use your key and unlock your driver's door with it. Does the light turn off?
Old 05-11-2011 | 11:40 AM
rsmatti's Avatar
i tried that yeserday i locked the car outside(red light flashing). then used the key to unlock the car and the red light still flashed. when i opened the door same thing car alarm .
theres the ticker underneath the stearing column that is a black box there was a big red fuse next to it and a big blue fuse both were taped together i pulled out the blue fuse and it turned off the red light.
I'm still irritated I wanna know why this is happening
Old 05-11-2011 | 12:04 PM
egprelude's Avatar
If you have the factory add alarm alarm you can easily just remove it:
Directions: http://www.handa-accessories.com/S2000/s2ksecurity.pdf
rumcho
06-08-2013 06:22 PM
damn1tdavid
03-03-2011 09:33 AM
eunsangie
12-03-2008 03:42 PM
Dracoro
11-07-2003 04:18 AM
DJ Qube
10-02-2001 11:34 AM
Quick Reply: Immobalizer problem 2 days after tune
