If you guys are considering upgrading your engine mounts...
Old 08-27-2011, 11:29 AM
  #31
camuman's Avatar
Originally Posted by S1997
Update:
I have had the Innovative 75A mounts installed for less than a year, some of it on the track. Recently I could tell that something was obviously wrong -- vibration and engine sag on the right side.
I decided to order some 65A bushes and try them out before going over to the Hardrace mounts. so today I took out the 75A bushes (blk) and replaced them with the red 65As. The 75a bushes were some POS crappy polyurethane pieces that totally sagged and ended up deformed and misshapen. No wonder my car was vibrating so much. BTW the 65A bushes are very much like the OEM Honda mounts as far as I can tell so far. JFYI Here are some pics of the 75a bushes that I removed: (click on the pics for a better view)
The pics are from the passenger (torque) side motor mount.
Hope it works out. But they don't have a good track record.
Old 08-27-2011, 01:26 PM
  #32
S1997's Avatar
Ya, I had forgotten that you have to take the Innovative mounts out in order to change the bushings. Otherwise I would already have had the Hardrace mounts in my garage to put on. I'm not even going to bother trying to get warranty from Innovative. Bummer. Maybe the 65As will hold until I can order the HRs. The OEM mounts didn't hold up on the track, either, and I don't have near the hp/tq that some of you guys have.
Old 08-27-2011, 01:48 PM
  #33
Soul Coughing's Avatar
Update:
Wow, that's unacceptable. I was thinking of getting those, but I think i may do what O'Malley did and get those upgraded stock mounts. I'm guessing they drain the stock fluid inside the mount and replace it with something hard?
Old 08-27-2011, 01:55 PM
  #34
S1997's Avatar
Some pics and descriptions here:
http://cgi.ebay.com/...T#ht_2673wt_941
http://cgi.ebay.com/...T#ht_2653wt_941
Old 08-27-2011, 02:06 PM
  #35
Spoolin's Avatar
Those Hardrace mounts look very promising. I think I'll be going with those.
Old 08-27-2011, 04:23 PM
  #36
wisdom's Avatar
Hardrace ones look very similar to the Megan ones or the Megan ones look very similar to the Hardrace units . Found a thread somewhere that says the same company makes the mounts.
http://www.meganracing.com/product.a...d=901&catid=54
Thoughts?
Old 08-27-2011, 04:59 PM
  #37
Spoolin's Avatar
Thoughts?
I bet those are the same. The pictures even look similar. At least the prices are comparable and one isn't trying to rip people off. The durameter at 70A is about right were it should be on them also. Sounds like the perfect solution to our crappy OEM units.
Old 08-27-2011, 05:21 PM
  #38
siadam's Avatar
I've got the 65a innovative on the passenger side, had good luck so far.
Sent from my iPhone 4 using Tapatalk.
Old 08-27-2011, 07:34 PM
  #39
jaundice's Avatar
My 65A passenger side died in less than 1 month with my PFab downpipe and dual dump tubes running next to it....
Old 08-28-2011, 08:33 AM
  #40
o'malley_808's Avatar
Mine lasted around half a tank of gas in 90+ degree weather.
Hardrace makes the mounts for Megan. I have the Megan version. Only difference is Megan slapped a sticker on them(which was half falling off when I got them lol)
Quick Reply: If you guys are considering upgrading your engine mounts...
