Idle popping
I would definatly lower the base pressure again you are definatly going to riding the line or going over the pressure relief of the pump allowing for no linear fuel deliver and reduced flow rates.
Shoot me an email with your map and data log and I will see if I can help.
Originally Posted by dsddcd,Nov 18 2010, 10:51 AM
Yes there is a good chance you are damaging the motor.
I also have rc750s, stock FPR, walbro 255 wired to relay. Air fuels when cruising are 13.6-15.6 fluacting depending on rpm and throttle input.
not sure if this is related but off idle currently, my afr's are real rich when rolling into throttle; makes the car seem like its under heavy load...
Originally Posted by s2k.igor,Nov 18 2010, 04:07 AM
My AFR from a cold start is bad, it starts rich 13.2 and goes to very lean while standing at traffic 16-18..
whe the car is warmed up the idle AFR gets better.... 13-14.
I recently retuned my car with the new 750cc injectors, with that I was hoping to get rid of the problem because I had the same problem with the stock injectors.
Should I lower the fuel pressure and get the car retuned? What adise can you give me?
Can anyone help me?
Igor
Can anyone help me?
Igor
Sometimes you need to adjust the fuel pulsewidth/ign timing/inj phasing to get it smooth. also depending upon your corrections that could also affect and contribute to your issues. if the AFR is changing while you are rolling into the throttle, it can also be the accel pump that needs to be adjusted.
60 psi of fuel pressure is a tad high, but not that extreme, especially if you're running only 8.5 psi. if you decide to adjust this, its going to through off your fuel table in boost.
fyi, how far are you from trento italy? theres a good chance ill be in italy tuning several cars after i tune in UK mid december.
wow mase is ansering
I was trying to come to Paris or UK last year but my car wasnt finished.... too bad I missed you two times...
Trento is not very far from vienna, 500 miles, I would even drive to UK for getting my car tuned by MASE!
I was trying to send you a message through MSN or through Phil in UK, no anser, pretty hard to get hold of you
I'm the first to come to Trento to get my car tuned! Let me know when you are in europe please!! Anytime!
BR,
Igor
BR,
Igor
s4play
01-25-2018 06:22 AM
