Idle popping
Old 11-17-2010, 03:22 AM
s2k.igor's Avatar
Default Idle popping
Hi guys,
my car is popping at idle every now and then, mostly at idle, sometimes right after I open the throttle, but mostly at idle. The car is even shaking as if it was caused by an explosion in the exhaust when I'm standing at a traffic light e.g.
Can it be unburned fuel in the exhaust or something else?
Maybe my fuel pressure is set to high? I think it's at 60 psi.
Can it make any damage to the motor? I'm trying to fix this problem and I would appreciate any help.
My setup:
VTSC @ 8.5 psi
AEM EMS
AEM FPR
RC 750cc
Walbro fuel pump
Thank you!
Igor
Old 11-17-2010, 03:35 AM
Deception's Avatar
From my experience RC injectors suck at idle, you have to run really rich or it will misfire constantly. Could be other things though too.
Old 11-17-2010, 04:19 AM
s2k dre's Avatar
Whats ur afr at idle?
Old 11-17-2010, 04:22 AM
joes sled 2000's Avatar
The popping is caused by too little a duty cycle for the given fuel pressure . If you turn down the static fuel pressure it will help the problem but youre car will need retuned . I recommend getting better fuel injectors as rc injectors are not the greatest . Id 1000s are awesome !
Old 11-17-2010, 05:08 AM
slappynuts's Avatar
Cars without enough timing on tip in will pop like that as well.
Old 11-17-2010, 05:40 AM
teamvalorracing's Avatar
i get that at idle. the motor is 100% stock except for a test pipe. even stock intake and everything. but i have my walbro 255 still in the tank from being turbo. i think it may be from additional pressure at idle as well, because i never noticed it while being turbo with the ID's.
ever since i went back to stock, its had a light shudder or *piff* every now and then only at idle in any condition( hot, cold, morning, night, 4 hour trip, 5 mins of driving).
compression reads 240 across the board and i have every emissions component working and installed. not a CEL in sight.
can anyone confirm?
Old 11-18-2010, 03:07 AM
s2k.igor's Avatar
My AFR from a cold start is bad, it starts rich 13.2 and goes to very lean while standing at traffic 16-18..
whe the car is warmed up the idle AFR gets better.... 13-14.
I recently retuned my car with the new 750cc injectors, with that I was hoping to get rid of the problem because I had the same problem with the stock injectors.
Should I lower the fuel pressure and get the car retuned? What adise can you give me?
Can anyone help me?
Igor
Old 11-18-2010, 05:43 AM
InductionPerformance's Avatar
PM'ing you
Old 11-18-2010, 05:51 AM
dsddcd's Avatar
What? I have had no trouble with any of the High Impeadance RC's?
Must be the tuner?
My setup:
VTSC @ 8.5 psi
AEM EMS
AEM FPR
RC 750cc
Walbro fuel pump
Yes there is a good chance you are damaging the motor.
Why would you run 60PSI base pressure???? You need to keep it lower, say 43 PSI w/ no vacuum attached. The Walbro pump has a pressure cutout at 75PSI and you are going to hit this VERY easy with a little boost and the line losses to the rail.
Have you called your tuner this should not be happening and with your description without a data log with AFR there are none of that are going to be able to give you a good answer. If you Tuner set this up it is time to find another.
Save your money useless you have a bad injector buying new ones will not held. ID1000's are great b/c they have the ability to flow more fuel than was previously possible with a High Impedance injector and still exhibit good linearity.
Old 11-18-2010, 06:55 AM
s2k.igor's Avatar
I'm running 60 psi base presure because my tuner said it's ok and tuned it like that. I don't like that but he's the only tuner here in Austria who can work with AEM EMS. I wish somebody with skills could tune my car but as long as I don't have any other option I have to stick to my current tuner.
Quick Reply: Idle popping
