i need help
i need help
hello peeps. I have decided to change a few things up on my build and right now im in a pickle. I have a borg warner s363 polished with a straight cover and a 2in inlet. I need to find a cover that has a 3in inlet.
im willing to trade somebody STRAIGHT UP for your unpolished straight cover with a 3in inlet!
any help or advice would be much appreciated fellas
Borg Warner does not make a 3" inlet compressor cover, even in the S200SX lineup, they all are 4" ported inlets.... It looks like you might be talking about the outlet, which in this case the FMW compressor cover (only used by the FMW) that you are using is actually a 4" inlet, 2.5" outlet, BW changed this cover because many do not need a 3" charge pipe system, where 2.5" is the industry standard for most applications. To go with a 3" outlet you would either need to replace the turbo, no turbocharger in the Airwerks lineup uses the same inducer sizing as the FMW (61.4mm) or use a transition silicone coupler to match your current setup.
thanks for the info! lol yes i was talking about the outlet, my bad. im trying to fit a 3 in wiggens clamp, that is my cause for the new cover.
how it looks now...
how it looks now...
i do, iv got a TON of goodies both pretty and function to add then a retune hopefully before xmas then ill post up on my thread. this is the one thing holding me down...
slanguage
06-06-2004 06:40 AM
