I keep losing bolts like an 82 Buick help!
Hey just wanted to find out what you guys are putting on your bolts on your turbo manifold, ive tried new bolts, lockwashers and tightened the crap out of them but they still rattle loose. The most popular ones going missing have been the turbo to manifold 3/8 inch bolts. Should I put some sort of temporary locktight on here or will it just melt with the heat?
Originally Posted by AusS2000,Oct 18 2008, 02:02 PM
I trust you're not using 3/8 inch bolts? They are 12mm metric studs and nuts.
And then my wastegate likes (8mm threads) like what the hell cant they keep it all the same?
It'll melt right off, just tack weld them and be done with them.
Use a grinder to take them out.
I also had that same problem and had them tack welded the problem never came back
