I Cant Keep Turbo Flange Bolts From Snapping?!?
Old 02-09-2012, 09:43 AM
B5254T4's Avatar
I have a brand new black T1R blanket if anyone need it, let me know.
Old 02-09-2012, 01:08 PM
o'malley_808's Avatar
How did this turn into a turbo blanket thread? lol. Its a DEI titanium
Old 02-09-2012, 02:36 PM
ftpsk8's Avatar
Im using bolts from ace hardware...
Using turbo blanket from ptpturbo on ebay. Works great so far.
Old 02-09-2012, 05:00 PM
japhethwar's Avatar
My ptp blanket lasted about 1500 miles before turning to dust. I use Grade 8 bolts from home depot with a large flat washer under the lock washer, have had zero issues. Try adding a large flat washer i'll bet your problem goes away. It isolates the bolt from the turbine housing, allows it to expand without breaking the bolt off. I gave up on the blankets and heat sheilding and bought a vented hood. Heat is no longer an issue.
Old 02-09-2012, 05:08 PM
S2K-F8's Avatar
I'm using the same...grade 8 bolts, flat washers, and nuts. I ditched the standard lock washers in favor of Nord-Lock washers to prevent everything from backing out/loosening up
Old 02-09-2012, 05:31 PM
spdracerut's Avatar
That's really odd..... is the downpipe banging against the firewall? Do you have a flexpipe on the downpipe?
Old 02-09-2012, 05:34 PM
MegaTRon's Avatar
order the Honda oem bolts for the catalytic converter. can't beat oem quality, especially Honda's
Old 02-09-2012, 06:28 PM
TonysMI4's Avatar
I also got an DEI turbo blanket and it went to Crap after about 1000 miles. It's like the inside has came all apart and now there is all kinds of fiberglass or whatever it is from the cover all over my motor. It got into places that can't be good for it.. good thing about it, I get them at cost.. let me know if you want to try another one.
Old 02-09-2012, 06:41 PM
03supers2k's Avatar
http://www.full-race.com/store/turbo...dware-kit.html
+ Nord lock washers
jtins2k
12-16-2011 12:00 PM
H4RD ON
02-22-2011 02:49 PM
AusS2000
12-19-2008 06:25 PM
o'malley_808
10-25-2008 07:54 PM
ChefJ
06-20-2007 06:08 PM
Quick Reply: I Cant Keep Turbo Flange Bolts From Snapping?!?
