How much power am I looking at?
Hey guys! Im looking into buying an inline pro kit and from what ive heard, its safe to run 14psi on the 3mm HG. With 14psi and the kit what would i be looking at to the wheels?
What would be the power number difference from the BB turbo upgrade?
I know that alot of it is the Tuner, if not all of it, but lets just say I have a good tuner that does the work, what would the numbers be?
Depending on which turbo you go with @ 14psi probably around 415rwhp. But with a 3mm HG you can turn the boost up more then that. I ride around @ 16-18psi and iv had it up to 23psi. Iv also overboosted to 25psi without any problems.
Originally Posted by StatixNWH,Feb 3 2007, 08:37 PM
dang! inline dosent recomend that but ill take ur word for it....how much power did you have on 16?
Originally Posted by OGPackin,Feb 4 2007, 06:56 AM
No worries bro...Iv had my setup for about a year now and i havent had any major problems (knock on wood) Iv never used c16
i made 400 at 14psi and had it for a year and ran great and i also you to have some 22lbs spikes and hold for no problems on cold nights ....... i had gt30 kit with 3mm hg and aquamist never had a problem drove like 20k miles on it and 8 to 9 lbs daily and 14lb high boost
thanks for answering my questions guys! so im looking around 420-540 depending on boost. sweet! ill keep you guys updated when the turbo setup is in progress
