How much boost on a stock motor?
So I've been thinking about adding a little more boost on my stock motor. I've been looking at what others have been running with lower comp pistons and head gaskets and from what I've seen I think it can take it. Follow my train of thought here and tell me if I'm nuts. Stock compression of the F20c is 11:1. That's also what the "effective" compression is. Now stock 11:1 with 8psi, the effective compression rises to 16.9:1. Which so far I have been running no problems. Now take the Inline Pro kit, it runs at 18psi with a 3mm head gasket. The gasket drops the compression ratio down to 8.8:1. With 18psi of boost you get an effective compression ratio of 19.6:1. Same thing if you run CP or JE pistons at 8.5:1 with over 20psi of boost.
So with a stock 11:1 with 12psi of boost the effective ratio is at 19.7:1. I think that should be safe, considering I'm running EMS and can retard the timing, where Inline just uses a map defender.
Am I crazy or does this make sense to anyone else?
Originally Posted by Scorpion,Nov 5 2005, 06:07 AM
No opinions on this?
Why not try 10 psi first and see if you can get an effective tune? I would think you would want a good balance of timing and boost. I have not heard/seen anyone doing 10 as of yet. Do you think you have enough injector for 12 psi? I am not sure, that's why I ask.
Baby Steps, Scorpion... Baby Steps..
LOL the problem with baby stepping it is that I'm going to be using the GM 3-way solenoid and EMS for boost control. And after a lot of research I have found that the solenoid is not very affective for small increases. So the fact that I have a 8psi wastegate spring doesn't allow me to go much less that 12psi. My injectors are a little on the small side. However, that's nothing that a 10psi increase in the fuel pressure system won't fix
I say turn it up! And put fuel cut low in the PSI(Setup, rev limiters) so that if you make a b00 b00 in figuring out the GM Boost control selenoid, you dont see 20psi of boost
BTW, I miss boost. I just got my car running again, all-motor. 10:1 compession on stock exhaust(and cat) is REALLY slow; especially when running on the same boost map that I always have been
Hopefully by Thanksgiving Ill have my car up and running, on the way to the tuner with some good basemaps for you all to mess with(boost control selenoid).
Originally Posted by Tinker219,Nov 7 2005, 07:15 AM
actually Brian, you have a .4 bar spring, which I believe is a 5.5psi spring. The efficiency of the GT series turbos throws the TiAL ratings system right out the window; and there is about a 1psi creep-factor built into the manifold(not on purpose, but the wastegate has to fit somewhere!).
My plan for the EMS was to set fuel cut at 13psi. That way if there is any spikes or I set the sloenoid up wrong it won't tank the motor . I just finished installing the solenoid last night, it's connected to a switch mounted under the dash, so I can run hi/low boost. Tomorrow I will be cranking it up and doing a quick street tune. Hopefully by the weekend I can get it on the dyno and see what she makes with the extra 4psi.
We also have the same question
When we had the vortech supercharger we boosted daily about 1bar~14Psi and we allso tried a while on 1.3bar we had no problems.
But the SC doesn't put down at the same boost as the turbo.
We have AEM EMS 720cc spridare injectors stock engine with 3mm Cometic gasket running on 8.8-9.0 CR, lovefab GT1, GT35R how much you guys think we can boost?
I would like to try and understand how you think efficiency can change the physics of a spring
thus, placement of the wastegate on the manifold can negate some of the actual boost pressing against the wastegate spring by means of "laminar physics." I am not in a position to say that Tinker did this on purpose but seeing as it is not an equal length manifold it makes this happen much more easily. When all the tubes are not equal then there are 4 different airflows that are going to have 4 different "angles of attack" on the inner walls of the manifold just before the wastegate opening which creates turbulence in the airflow that can fool the wastegate. So is short, yes it is possible to create greater boost than the wastegate should theoretically allow.
So all that said in explaining creep you still have this turbulent air. The GT turbos are effecient enough and spin easily enough that the turbulent air spins then just as easily as clean air.
