How dangerous is 3.6psi
Old 10-10-2006 | 07:34 PM
NFRTurboTerror's Avatar
Default How dangerous is 3.6psi
I have the rev hard kit with 650cc injectors. I also bought a 3.6psi wastegate spring. Is it safe to run that much boost on those injectors until i get an ems? Or should i just hold off on the install for another couple of months(holidays are coming so money will be tight for a little while) and just do when i get the ems.
Old 10-10-2006 | 07:53 PM
Enthralled's Avatar
yes....wait.
Peace
Old 10-11-2006 | 03:17 AM
cpoz's Avatar
Wait, and do everything at once.
Old 10-11-2006 | 08:40 AM
Dsgs2k3's Avatar
couldnt you install the turbo and run oem injectors for 3.6psi of boost.
Old 10-11-2006 | 08:52 AM
XclusiveAutosports's Avatar
With the oem injectors and an FPR I think that would be doable, but what management are you going to use in the mean time before you get an EMS? For the kick that 3.6psi is going to give you, I would just wait off an do everthing at once though. Taking your WG spring in/out after the turbo is installed is usually not fun depending upon your kit.
Old 10-11-2006 | 09:00 AM
CourageOO7's Avatar
This whole thread sounds like bad news to me...the stock ECU doesn't know what to do with 650cc injectors (if that's what you're asking). Do you want to risk a blown motor? I've been there...it sucks and it costs way more than an EMS and a good tune.
Old 10-11-2006 | 12:25 PM
WolfInSheepsClothing's Avatar
You could run an FMU for 3.6psi, but you will need to block the map sensor from seeing positive pressure otherwise your car will stutter/stall/run like crap, because the map sensor will freak when it sees boost. But, i doubt that you will be able to maintain such a low boost pressure (you will most likley creep). So, I would just save up for the AEM EMS if I were you....
Old 10-11-2006 | 12:31 PM
Dsgs2k3's Avatar
if you just plan on running that amount of boost and dont plan on running anymore, then you could get a comptech ESM and a tuning tool like a VAFC
Old 10-11-2006 | 12:39 PM
or just get an FMU and put a check valve on the map (if you really want the cheapest route)
Old 10-11-2006 | 02:27 PM
Im not planning on staying at 3 psi. I also dont want to use an FMU unless i absolutly have to. I already have the injectors and fuel pump and i amd going to buy the AEM EMS once i have the funds so it seems like a waste of money to get an fmu. Another problem i have is i dont know of anyway to get my car to the tuner(3hrs away), once the kit is installed. I dont know anyone that lives around here with a truck or a trailer, so im more than likely going to have to drive it there no matter what.
Quick Reply: How dangerous is 3.6psi
