Hondata announces 00-05 S2000 ECU's
Old 03-05-2007 | 10:38 AM
djmatix's Avatar
Default Hondata announces 00-05 S2000 ECU's
1 Mar 2007
We are pleased to announce a programmable ECU solution for the 00-05 S2000.
Full details are at http://www.hondata.com/s2000kpro.html, but a summary is below:
- RSX ECU modified to suit the S2000 wiring harness.
- same features as the RSX KPro - covering big injectors, boost, nitrous, ITBs, boost control etc
- some mechanical components need to be updated to the 06-07 parts.
- will not work on the 06-07 (due to drive by wire)
- available early May (estimated date only).
- price $1795 plus approximately $300 of Honda parts.
We would request that you do not call us for more information. We will do our best to answer any questions on this forum or our forum, and either update the page on our website or update this post. If there is something you desperately need to know - you've survived 7 years without knowing so far, just be patient.
Questions / Answers
Photos - we'll take some photos next week. It looks just like the RSX KPro, except the S2000 connector sticks out approximately 1.5".
Power gain - ECUs do not make power. Engines do. A badly tuned ECU can reduce power, but the rest is up to the engine. With the S2000 KPro the engine will be able to obtain it's maximum potential output.
Existing ECUs - we only will offset the S2000 KPro with a new ECU from Honda. Existing ECUs, KPro or not, cannot be used.
Base calibrations - We have an AP1 basemap, and should get an AP2 basemap before the release. Basemaps are just a starting point, and people should realize that a good tuner can replicate whatever basemap we might provide in about 10 minutes.
Primary/Secondary o2 sensor - closed loop runs off the primary oxygen sensor. It cannot run off the secondary oxygen sensor because the cat changes the AF ratio. What we have done, on ECUs which don't support a narrow band primary oxygen sensor, is to route the S2000 oxygen sensor via the secondary oxygen circuitry. Internally the ECU treats the secondary as the primary and ignores the secondary.
Widebands - You can route the wideband analog voltage output into the ECU ELD input for datalogging purposes. The PLX wideband is $195 with sensor (no display) and $315 with display. It has both narrow and wideband analog outputs too. I've been told the NGK wideband is good. http://www.ngk.com/afx/ $295 with display and wideband analog output.
Old 03-05-2007 | 10:44 AM
djmatix's Avatar
ALL INFO
Old 03-05-2007 | 10:45 AM
PRS2K's Avatar
Sounds Great. For the price AEM still seems the way to go.
Old 03-05-2007 | 10:50 AM
ChefJ's Avatar
This will be a great option to have in the future.
PRS2K's Avatar
I read some more of the details. Which makes the AEM even better of a buy.
S2000 Kpro $1795
additional Parts $295
Total $2090.00
Even more for those who can't install there own parts that are needed for this to work $$$$$$$$
The only feature the AEM doesn't have is the Temp gauge which can be fixed very easily and VERY cheap.
I'm glad there is another option for the S2k community. But in my opinion the AEM EMS is still the better buy "HANDS DOWN"
Old 03-05-2007 | 11:10 AM
ya@inlinepro's Avatar
this will be well worth it on the s2000!!!
Old 03-05-2007 | 11:21 AM
elusiv's Avatar
Glad the option is there, but at that price I'm not sure I'd go for it...
Very interested in the results of this though!
Old 03-05-2007 | 12:13 PM
S2Kyle01's Avatar
AEM with the 6' harness and the temp fix is still cheaper and has been out alot longer so theres no weird bugs to work out as much.... Big ups for hondata im still a big fan of the S300
Old 03-05-2007 | 02:32 PM
Slows2k's Avatar
https://www.s2ki.com/forums/index.php?showtopic=467482
Hondata
04-06-2011 06:37 AM
K20Tuned
23
07-06-2009 04:04 AM
Hondata
07-24-2008 10:17 AM
djmatix
03-05-2007 06:44 PM
signalpuke
03-05-2007 04:30 PM
Quick Reply: Hondata announces 00-05 S2000 ECU's
