HELP! SoS Stage 1 AP2 Starting Problems
So i recently installed my SoS Stage 1 into my 07 AP2. I have read and read everything but this issue just recently started to happen. now everytime i try to start the car it starts then dies. This only happens when the engine is cold and not when i have been going around driving. i recently did a trip to home and i had to use 91 gas cause there is not 93 gas. anyways im thinking its because i have put 91 instead of the 93 i put when im at my home. also im thinking my broken primary O2 sensor has something to do with this. Anyways after 6 or more tries it starts up like normal and its like nothing happend. i just wanted to see if anyone could input there suggestions. thanks! ill try to upload a vid in the next hr.
EDIT : VID
[media]http://www.youtube.com/watch?v=4jEJXQKogQ8 [/media]
EDIT : VID
o shit that was fast... errors already happening with this kit. It can't be because of the 93 octane. Over here all we have is 91 octane. Something seems funny about the tuning with the hondata
do you have oem plugs in? maybe the plugs are too cold (step wise), i know last winter i had trouble starting bc the plugs were a couple steps colder than oem, once it heated up everything was fine but then it got so cold that it wouldnt start at all so i threw in oem plugs and started right up... weird but it worked for me
Former Sponsor
All Hondata reflash cars with larger injectors (SOS, Kraftwerks, Vortech) start properly in my experience.
If your car has an existing check engine light, there is an existing problem that more than likely will affect the starting performance of the vehicle. A "broken O2 sensor" - not sure exactly what that means, will definitely cause poor starting performance. Please address this, and determine if it is the cause of your check engine light, before proceeding.
Cheers,
-- Chris
Cheers,
-- Chris
Former Sponsor
regards,
-- Chris
1 Post
Im sure the check engine light will probably answer your question to your starting issues.
Originally Posted by Chris@SoS,Sep 15 2009, 09:44 PM
It's premature to jump to such a conclusion with an existing issue on the car.
regards,
-- Chris
regards,
-- Chris
also... i used to have random hic-up's on my s/c set-up before... Then i got it re-tuned and i never had this issue again.. even on the coldest days to the hottest days. just throwing out a guess you know
Originally Posted by 518135,Sep 15 2009, 09:51 PM
There is nothing wrong with Hondata. There was a few guys that had a couple of hick ups in the beginning with cold start issues. No big deal! Problem was fixed.
