Help with my disappearing coolant
Help me with my disappearing coolant. I have to add about a half a quart and bleed it every time I drive it. My engine is a brand new build with Darton sleeves, OEM head gasket, ARP head studs and a milled head all with less than 150 miles on it. I also deleted my heater core. I pressurize my radiator to 20psi and there is no visual leak anywhere. I also pressurized my cylinders individually to 60psi and looked for any bubbles in my radiator or bleed valve. Nothing!!! I also ran the car to operating temp and then immediately took out the spark plugs and put a mirror over each cylinder to check for steam. Nothing!!! I am at a loss here. I would assume it is a head gasket but there is no sign of it being that. Any and all suggestions are welcome.
Yup when I installed Turbo kit had to burp and fill overflow for a week, I thought something worse was going on to but just kept topping off and keeping an eye on temps and everything leveled out and stayed within operating temps.
