Help with CT vacuum hose connections
I'm running a 2002 Comptech SC with aftercooler.
Can anyone help me identify where A and B connect to? Kit is second hand, so I may be missing hoses... and the instructions on the comptech website are a bit difficult to understand.
thanks in advance.
Have you got the Comptech aftercooler?
If you have they connect to that.
Comptech aftercooler fitting instructions.
not sure what A is, but B will not connect to anything, just go to autozone and find a filter element to stick over it as it is still sucking air. Is A your BOV..if so just run a hose from that to one of your vacuum hose back to where your FMU is.
yes, i have the aftercooler also.
the aftercooler has 3 openings on it. 2 are used for the coolant to flow in and out, and the 3rd opening is for B... but im not absolutely sure
Where does A connect to?
