Heatsoaked SC aftercooler
Old 07-11-2010, 04:31 PM
  #81
RAIN H8R's Avatar
Joe, I get heat soaked after accelerating in 3 gears. Then my EMS pulls ign/fuel timing so I have no throttle response. I need to address this issue before our next track day.
Old 07-11-2010, 05:58 PM
  #82
RAIN H8R's Avatar
Also, I found a better idea, Ill buy your supercharged kit.
Old 03-31-2011, 01:29 PM
  #83
Banned
Kyushin's Avatar
Great info so far, im still curious as to what the optimal size pump would be...
Old 03-31-2011, 09:05 PM
  #84
IAmTheRealAsif's Avatar
I would say FMIC. You will lose 3 PSI but it should run cooler. And its simpler.
Somebody said UR FMIC is limited to 300whp? Why is that? Would tossing a bigger FMIC in fix that?
Old 03-31-2011, 09:46 PM
  #85
Former Sponsor
Moddiction's Avatar
Won't be able to max out the blowers with a fmic. Will overspin it before you can make the power you would with an aftercooler. Also overwork the blower for less power and can get more belt slip if you have like a 15 psi pulley being used to make 12 psi. I guess if you only wanted like 10 psi max it could be a good way to go though besides losing the throttle response.
Old 04-01-2011, 06:07 AM
  #86
Sportster's Avatar
I have not tried it, but a lot of people using the aftercooler have gone with a water wetter and they have seen very good results.
lude92_si
07-16-2013 02:59 PM
wait4vtec
08-23-2011 07:26 PM
SDS2K@9K
03-29-2006 07:39 AM
Quick Reply: Heatsoaked SC aftercooler
