head setup for 600 whp
Old 03-26-2009, 07:43 AM
Former Sponsor
Peter@ISP's Avatar
I think its def worth it to port the head. you dont have to run as much boost in order to get max out the turbo. for example, look at how much boost evo motors have to run in order to make similar power of f20,f22 motor. you are correct though if it is not ported correctly it will make less power...
Old 03-26-2009, 09:19 AM
siadam's Avatar
I would put the $$ elsewhere instead of the head for the 600whp mark. If you were going beyond that, I can see the benefit quickly becoming apparent.
Old 03-26-2009, 10:23 AM
boostedf22c's Avatar
Originally Posted by MrSmith,Mar 26 2009, 07:18 AM
I would go with Ferrera or Supertech.
When did Ferrea and Supertech start porting heads?
Old 03-26-2009, 10:38 AM
fadiss2k's Avatar
they dont....they make the parts he is wanting to buy.
Anyone know anything about dh racing black nitride chrome moly spring and retainer kit?
This is exactly why it's VERY beneficial for the EVO guys to port the head. I don't see a huge advantage for the cost if you are boosting an F20/22 to port the head. I mean, I make 600whp at 20psi of boost on a stock head with just springs and retainers. So what, I could spend $1500-$2000 for a good port job on the head and make 620whp at the same boost? Shit I'll just turn up the boost 1 lb and make 20whp....hahaha.
You HAVE TOO port an EVO head to make power (within running an insane amount of boost), you don't have too with an S2k head. Look at the crazy stock motor guy that's making 700whp on a bone stock long block under 30psi of boost.
Are there performance advantages in porting an S2k head? Yes, if done properly. Is it worth the cost? In my opinion, no, unless you are trying to squeeze every last ounce of power out of the motor. Which would be WAY TOO MUCH for the street....haha
Old 03-26-2009, 10:39 AM
I know that, but that's not what he said. Unless I interpreted what he said wrong??
Old 03-26-2009, 11:21 AM
Former Sponsor
Peter@ISP's Avatar
boostedf22c
i guess it depends on one's budget but i've been a firm believer in running less boost and making most out of it rather than just turning up the boost.
Old 03-26-2009, 11:30 AM
candymanjl's Avatar
talked with Mase about this a little and the S2000's benefit very little from head work. he's seen fully ported and polished heads only gain 10whp on a 500whp motor. he's also had some heads lead to a lot of smoke in the exhaust, swap back to the stock head and the smoke goes away.
B-series motor and there's lots of power to be gained from porting and polishing, our F series motors, save the money for something else valves, springs, retainers yeah, let you rev out more, but I wouldn't port the head.
Old 03-26-2009, 11:39 AM
siadam's Avatar
Thats what I said.
B series motor make solid power on a stock head until around the 600whp-650whp mark, and our heads flow better than b-series, so it only lends to reason that they would be solid until that level, give or take.
Old 03-26-2009, 06:34 PM
Originally Posted by Peter@ISP,Mar 26 2009, 11:21 AM
boostedf22c
I agree, but you also have to look at performance to dollar. It's worth it with an EVO to port the head, as they flow very poor from the factory, it isn't with an S2k. You just don't gain enough to merit the expense IMO. Of course I'm talking about FI motors.
Quick Reply: head setup for 600 whp
