Head Bolt Retorque w/ InlinePro 3mm Gasket
So, I have the car nearly ready to get tuned on Friday and I am trying to get finished up however I keep thinking about the head gasket. On my previous build the head gasket manufacturer SCE recommended that I retorque the head bolts after heat cycling. InlinePro however did not make mention of this in the instructions for the new gasket.
Is there a need to retorque? Being that the factory headgasket does not require/recomend it I am inclined to say no but it only takes an hour so if it won't hurt I will do it.
Also the new head studs that I installed from ARP had noted in the instructions that the nuts be torqued to 95 ftlb where as another set I installed on local members car only required 85 ftlb per the instructions. Did anyone else notice this?
so the same model of headstuds from ARP required different torque numbers? you sure one wasnt with oil and one wasnt with the lube? i think i did hear something about ARP releasing new torque numbers for some of their studs. btw i think i did mine to 95....
Originally Posted by JoeyBalls,Jul 5 2010, 04:28 PM
Not threadjacking, but somehwat related, Where do I get "Molly lube" I heard I need it with the ARP Headstuds, Ia m trying the over my prematurely failed OEM
I'm sure you can order it from Summit/Jegs as well.
