Have you guys replaced your oil pump with a more ROBUST brand?
My guy says its a 7 hour labor job to remove/replace the oil pump!
Looks like mine maybe going bad with only 15k miles so I'm looking at the opportunity to replace this with a better quality unit. Is there any brands that you guys have used that is proven?
Since this seems to be a crucial part, I was thinking of using a more robust unit, thoughts? Any insight appreciated!
thanks
rick
thanks
rick
Since we have the F22C1 motor, would this ERL oil pump work?
http://www.hybrid-racing.com/store/e...or-kswaps.html
Maybe I'm illiterate, but this seems like its meant for a k series motor not an f20. Its a modified s2 pump on a k block. Correct me if I'm wrong But when the opening line says are you building a high revving k-series........
Have you checked the actual pressure with a guage. It is not uncommon for oil pressure senders to fail, or for small pieces of trash to become lodged in them making for false readings. Have him screw a guage in the sender port and monitor the actual pressure probably gonna find its not the oil pump. Oil pump failure is rare, unless its been run dry or excessive amounts of trash have gone through it. If thats the case your gonna need a lot more than just a pump. Check oil filter as well, have seen more than one filter come apart inside and cause a partial blockage. Though that was with cheap filters (fram). If the pressure readings are good its probably gonna be the sensor. Good luck
^yup we already checked the oil pressure with an actual gauge screwed out - very odd to fail but ours is not holding any pressure
I'm considering buying an OEM modified/upgrade pump from these guys:
http://www.theoldone.com/components/..._oil_pumps.htm
Anyone have experience with them?
