Has anyone run a water to air setup for kraftwerks or TTS yet?
Old 07-30-2014, 10:36 AM
  #21
06S2k07Si's Avatar
http://i1117.photobucket.com/albums/...713_145207.jpg
https://www.s2ki.com/forums/index.ph...age&img=845695
Old 07-30-2014, 10:49 AM
  #22
michaelnyden's Avatar
So if the KW blower weren't shifted over like that towards the TB it might work. Looks like a custom aftercooler would need to be made then.
Old 07-30-2014, 10:50 AM
  #23
06S2k07Si's Avatar
Originally Posted by michaelnyden
So if the KW blower weren9t shifted over like that towards the TB it might work. Looks like a custom aftercooler would need to be made then.
Sounds right.
Old 07-30-2014, 10:56 AM
  #24
06S2k07Si's Avatar
The KW kit seems to be shifted over further than the TTS kit...maybe the KW kit could work with the SOS cooler...
http://ilovemyhonda.org/wp-content/u...e9829f9642.jpg
Old 07-30-2014, 11:02 AM
  #25
Sorry, didn't realize the TTS was the one in the earlier pic which is shifted over...the KW kit might work as 06S2k07Si pointed out.
Old 07-30-2014, 11:17 AM
  #26
Redline S2K's Avatar
Originally Posted by Moddiction
On their site it says 120 degrees however looking at the blower I don't see how that is possible. It would need to be counter clockwise to come out to the right on the bottom. From looking at installed images it would be coming out on top.
Exactly. The C38 would come out of the top to face towards the intake or any aftercooler you install there. The TTS kit is mounted more towards the throttle body than the KW but it would still put the outlet ontop of the blower. If you look at all the Rotrex datasheets, the c8 and c8T are the only blowers that would rotate the outlet to the bottom if you repositioned it. When I was looking into this idea myself, there seem to be some aftercooler that could possibly work on frozenboost.com but the setup would likely be very ugly and/or require a 180 degree pipe off the blower, hurting flow like Junky stated earlier.
http://www.rotrex.com/Home/Technolog...Technical_Data
Old 07-30-2014, 11:44 AM
  #27
Doesn't the original kraftwerks kit have a 180 degree bend coming right off the blower?
Old 07-30-2014, 11:47 AM
  #28
06S2k07Si's Avatar
Doesn9t the original kraftwerks kit have a 180 degree bend coming right off the blower?
Yes...as a previous owner, it is a very sharp J pipe.
Old 07-30-2014, 11:53 AM
  #29
And that kit still made 10psi on the high boost pulley and generated good power.
Old 07-30-2014, 11:56 AM
  #30
06S2k07Si's Avatar
Yes...through a very restrictive intercooler too...compared to the TTS IC.
Quick Reply: Has anyone run a water to air setup for kraftwerks or TTS yet?
