Has anyone run a water to air setup for kraftwerks or TTS yet?
This likely wouldn’t work very well due to the short run between the blower and Aftercooler if it could be done at all. The VT CT SOS all have a different shape aftercooler and offset and therefore distance/alignment to blower, but if one of them could work, the coupler angle would surely be a severe 90 degree on both ends, and you would lose some efficiency for sure. If the Rotrex wont clock in the right direction with the outlet volute on the bottom, then it may not be worth the attempt.
On the TTS kit the blower is too far to the driver9s side to fit the SOS cooler in there.
If you were making one you could just keep the blower in the same position and use a 180 deg off the blower output (its 2.5") and under the intake, then back to the TB. Maybe fab one in a similar fashion to an SOS piece.
Former Sponsor
On their site it says 120 degrees however looking at the blower I don't see how that is possible. It would need to be counter clockwise to come out to the right on the bottom. From looking at installed images it would be coming out on top.
Originally Posted by michaelnyden
I wonder if a 180 degree bend tube would work?
