GT35R Oil Feed Line Size & Oil Return line Size
Hey Guys,
Just needing a quick answer I cant seem to find.
What is the oil feed line size for a Garrett GT35R? -3 or -4?
and what is the oil return line size as well?
Thanks
Thanks
Originally Posted by s2000 or 240sx,Jan 26 2011, 09:04 AM
I used a -3 fitting for the feed line and a drain flange with a 5/8" drain fitting and drain line.
But I already have my oil pan tapped from my vortech setup but the Oil return line that came with the Turbo fits the oil return adaptor but not to the vortech's oil tap adaptor because it it is smaller then the turbo's oil return line, So I need to find the size of the oil return line and then get a reducer so that it would screw on to the smaller adaptor on the oil pan
you can use a -3 or -4 oil feed line. it does not matter. The important thing is that you must make sure you have a .035 oil restrictor fitting before the turbo.
as for the oil return most people run -8 or -10 . Try to run -10 if you can.
http://store.forcedperformance.net/merchan...de=Acc-OilLines
The restrictor
you can get lines im sure from any supporting vendor on this forum
The restrictor
Originally Posted by godmachine,Jan 26 2011, 05:03 PM
would this line work as my oil feed line:
http://www.atpturbo.com/mm5/merchant.mvc?S...y_Code=ATP-OIL1
