GT35r and the lovefab v1
I'm ready to upgrade my turbo from gt30r to gt35r now that I'm getting a built block. My question is is there any modification to the frame or something like that with the lovefab v1 and the GT35r?
Can i see a pic with this setup.
Than you.
Than you.
The V1 is a high mount and not close to any framework. There is a fair amount of space between the turbo and the engine and sidewall so I unless the 35 is much bigger you should be fine.
BTW, ignore RHD stuff.
AusS2000: so i should be fine with the GT35. if that a gt35 in your pic, i should not have any problems =)
is that a lovefab downpipe? i ask you because i have a full lovefab v1 kit, so the Gt35 should not change anything right?
Maybe I wasn't clear enough. That is a lovefab V1 and downpipe. The turbo is a GT3071R. I show the picture only so you can see how much room there is between the GT30 and the valve cover and body work.
Anybody else running v1 mani and gt35r?
Than you.
Than you.
