Gt35r with 106 exhaust
Old 09-03-2012, 07:04 AM
  #71
Irishflame27's Avatar
Originally Posted by bobbyrandolph440
What my set up is Nuttin like dog box its not straight cut gears http://www.libertysgears.com/faceplate-proshift.htm
They take off the syncro and weld on a big luged plate that makes it hold a lot better and its always available to public the only thing is u need the gto trans do to its better gear ratio for our cars and then having the bell made u have to ways on that force were they need the t56 and your stock s2000 bell and its 500.00 or full custom steel bell like I'm doing is 1000 but I'm going for track leagle stuff so it is also a scatter shield
Sent from my DROID RAZR using Tapatalk 2
what year GTO? who did the bell housing?
Old 09-03-2012, 07:12 AM
  #72
bobbyrandolph440's Avatar
Browell is doing mine will be least 4 weeks b4 its done and the 04-06 gto is what u need it has the 2.97 1st gear and depending what u are wanting to do with your car 4.56/4.88/5.13 are the best gears for rearend when u do the 8.8 swap if u stay stock 4.55 or 4.77 will be good also
Old 09-03-2012, 07:18 AM
  #73
Dog boxes have nothing to do with straight cut gears, you can have helical and spur (straight) cut gears in a dog box, the term "dog" simply refers to the gear engagement when syncros are not used, and the dog teeth of the gear are alot bigger, and spaced further apart which allow for faster shifting, as there is no syncro to slow the gear down before the gear change can be made....
The "face-plated" option you are using is converting 1-4 gear into a "dog box" style engagement
Old 09-03-2012, 07:27 AM
  #74
Yea that's my bad was thinking u ment full custom gear set that's my bad but yes that's what's happening its great for people like me that beat on trans the faster u go the faster u shift there are tons of utube videos pep can look at but my friend has his fbody done and I love it
Old 09-03-2012, 12:55 PM
  #75
JoeyBalls's Avatar
I would love to learn more about the T56 trans, but It is nearly impossible to read Bobbys posts, they are incoherent ramblings with a bunch of hella gangster talk . seems really cool though
Old 09-03-2012, 02:00 PM
  #76
Well then I guess stay off my topic
Old 09-03-2012, 02:20 PM
  #77
Corey Maurer's Avatar
Joey FTW
Old 09-03-2012, 02:22 PM
  #78
s2knoob89's Avatar
Makes my head hurt trying to read some of his posts. T56 sounds like a pretty solid option though.
Old 09-03-2012, 02:27 PM
  #79
Well that's how I am if u have a problem with it then find someone else willing to spend as much as I have to have the R&D done and get information from them about it
Old 09-03-2012, 03:39 PM
  #80
hybrdthry911's Avatar
So this will work with almost any s2k clutch or do you need a disc that works with the t56?
Quick Reply: Gt35r with 106 exhaust
