Gt35r with 106 exhaust
Old 08-31-2012, 01:20 PM
bobbyrandolph440's Avatar
Default Gt35r with 106 exhaust
OK so I have a Garrett gt3582r and t3 flange I'm thinking about going to a 106 exhaust has any1 done it and if so is there difference in how laggy the turbo is and max horsepower one guy on here done it and showed to make 706whp and that is close to what I want any help would be great thanks
Sent from my DROID RAZR using Tapatalk 2
Old 08-31-2012, 01:56 PM
Corey Maurer's Avatar
Bigger exhaust housing equals more lag and more power.. To put itt simple
Old 08-31-2012, 02:01 PM
Its just the houseing tho from what they said no fan swap or Nuttin I'm not real familiar with it that's why I'm asking
Old 08-31-2012, 02:03 PM
Irishflame27's Avatar
Bobby,
Will this be a divided 1.06 on an open T3 flanged manifold? You want to use bigger on the divided setups because the internal volume is actually smaller than that of an open volute housing.
If using an open manifold (undivided) stick with the .82a/r T3, The 61mm compressor will run out of breath before you see an issue with your turbine sizing.... .82a/r T3's have made 800+ whp
Old 08-31-2012, 02:11 PM
I was looking at t3 undivided I can go t4 divided if that will make the power and most I ever seen out of a 35r was 650s and that's what it is rated for Jw how can it make 800 I mean if it can great I'm looking to make over 720 is my true goal I'm on stock f20 block with up graded springs and retainer that's all
Old 08-31-2012, 02:39 PM
The 3582R compressor will never make 800whp, but if you step into the Forced Performance HTA GT3586R, you will do it....
Old 08-31-2012, 03:26 PM
I'm not really wanting to buy a hole nother turbo just upgrade mine if I can so what kind of power u think I'll make with a 106 on it
Old 08-31-2012, 03:31 PM
650whp give or take alittle, again the compressor is the issue
Old 08-31-2012, 03:52 PM
Can it be upgraded
Old 09-01-2012, 12:19 PM
godmachine's Avatar
In the evo world yes they make big power on the HTA turbo. Dont expect even close to that on a s2000.
Quick Reply: Gt35r with 106 exhaust
