Greddy Turbo Kit
i hope all you FI guys have a wideband, instead of measuring gas mileage as your indicator for your car running rich. that's horrible.
here are some must add ons:
1. turbo timer
2. boost gauge
3. wideband
4. 3"exhaust with test pipe and cel fix
5. boost controller (hallman with ceramic ball - i don't do electronic, they blow cars up)
6. EGT gauges (if you got money left over)
7. Oil pressure gauge
8. Oil temp gauge
9. transmission temp
10. setup safety limits first on any EMS. There should be more than 3 or 4 for a piggy back. AEM has over 50+++ safety features built in so you don't blow your car up.
11. lastly, Knock sensor indicator. I'm not sure if Greddy ultimate comes with one. AEM does, Hydro Nemesis don't.
and you MUST retune your safe map that comes with the greddy ultimate. That's universal map and every car is different. This is new and old, especially older cars. If you skimp out on retuning after the turbo install ($200 for retune or little more with a good tuner) then that's like buying a dog and not feeding it or teaching it to poop outside. it'll end up just crapping all over your house.
that's with every EMS manufacturers. AEM, Nemesis, Motec (well, not Motec), etc. They'll give you a safe map for you drive to the tuner after you install the kit, but that's where it should end. don't ever trust a universal map. That's there so you don't blow your car up when you start the car for a Tuner to custom tune your car.
1. turbo timer
2. boost gauge
3. wideband
8. Oil temp gauge
FI any NA cars expensive, because these things don't come with the car as a built in feature, because it doesn't need it.
lastly, if you're really good, you'll get the oil cooler as well.
1. turbo timer
2. boost gauge
3. wideband
8. Oil temp gauge
1. turbo timer
2. boost gauge
3. wideband
8. Oil temp gauge
All the gauges are fairly overbored for a simple bolt on turbo kit, maybe if you were into tracking the car it would be NICE to have but surely not necessary.
sure, it's overboard if your turbo was water cooled and oil cooled.
i don't think the 18g that comes with it is oil cooled. i might be wrong on that.
if it's water cooled, then sure, you don't need the turbo timer.
