Greddy oil return
Greddy oil return
Has anyone drilled the pan for the oil return on the greddy kit (instead of the drain return?)
I'd be interested in hearing where the best location on the pan is to do this. I'd prefer to not do it in the girdle. Thank you!
+1 on tapping the girdle, but I recommend you go forward & line it up a little over the drain's longitude. Don't go as far rearward as Ultimate Racing recommends, as it makes for a real PITA on getting a line plumbed to it without kinking.
Also consider an oil restrictor for the turbo supply if the turbo manufacturer recommends given our engine's high pressure system.
I followed these guidelines and have a pristine inlet tract (no oil leakage) on my GT3076R.
Didn't follow them on a prior T3/T04e and had slight leakage of oil into the inlet tract. No blue on exhaust or plugs, but still irritating to know the oil was coating the tract and reducing cooling efficiency.
Stanford
Stanford
I am sure Greddy has put a lot of R&D into their turbo kit. So I am sure if it were a problem with their turbo to have the line sharing the oild drain, they would have redesigned the setup.
I will guarantee you they did this from an 'ease of installation' standpoint (so DIY'ers don't stray away), than for a long term reliability of the end user...
There is no problem with Greddy oil drain share pen drain..They just trying to make the installion as easy as possible..
It just. i don't like re/re the hose for oil change all the time..
Originally Posted by Soul Coughing,Feb 5 2008, 07:12 PM
Like their tubular manifold design, emanage tunes?
I totally agree it's recommended so more DIY'ers will purchase their kit.
