Greddy Oil Drain
Oil drain? Are you referring to the return line going into the oil pan?
I haven't had any issues yet but have heard of a few that have encountered problems. One member recently melted his. My mechanic suggested converting to a steel braided line and tapping the oil pan to avoid this potential problem.
I had a small drip with mine. I definitely recommend at least getting the proper threaded fitting with a braided line to screw into the pan. Tapping the pan is the best option but the ct/sos adapter is great as well. Maybe sos will even sell you their return line.
Originally Posted by SgtB,Aug 8 2009, 01:00 PM
Never had a leak. Don't gorilla the clamps when you put them on. Just snug it until it will not pull off. It has very little if any pressure in it.
thanks, i am getting the greddy kit in a month or so, and i know that tapping the pan up above the oil line works better, just seeing if anyone had problems with the return entering the pan below the oil line!
thanks
thanks
