Godzilla BOV
Godzilla BOV
Do you need to adjust anything when installing the godzilla bov? Or can i just bolt it on and drive off? I don' have any experience with blow off valves and not sure if it needs adjusting.
You should be fine. Remember that you will have to generate high RPM to produce enough boost to make it loud.
You should hear it while cruising venting air and hear it "close" when you give it throttle.
You can adjust it like any other BOV if it the spring is too tight.
